Anyone know of a weatherproof 240vAC-12vDC power supply?
Discussion in 'Hobby Electronics' started by Rod Out Back, Jul 28, 2006.
  1. Rod Out Back
    Rod Out Back Guest
    Probably hundreds out there, but I wondered if anyone knew of a model
    that is reasonably weatherproof.
    Are any of the transformers for garden lighting weatherproof?
    Need about 1.5 amps at 12v DC.
    Cheers,
    Rod.....Out Back
  2. Ross Herbert
    Ross Herbert Guest
    Tridonic-Atco below ground transformers are plastic and epoxy cased
    http://www.tridonicatco.com.au/MEDIEN/CAT0304_AU/TRANS.PDF (p26)
    However, these are only AC, not rectified.
  3. speaking of which, does anyone know of waterproof small motors?
  4. Ross Herbert
    Ross Herbert Guest
