Anyone here ever programmed an FPGA?
Discussion in 'General Electronics Discussion' started by ratstar, Apr 5, 2021.
  1. ratstar
    ratstar
    478
    18
    Aug 20, 2018
    I've been doing GPU's for ages now, and I need to move onto something more mature.
    I'm wondering if FPGA's will make my robots run better than my GPU ones.
    What I need (even tho its slightly metaphorical) is to simply run something like frogger as many times as I can at once, I need to hit a collected (including parallel) frame rate of about 1 million fps or higher would be better. Because I need to sample a small model this many times to search in it.
    Will FPGA's be able to do this?
  2. Nanren888
    Nanren888
    455
    132
    Nov 8, 2015
    VHDL? It's sort of a different way of thinking.
    Parallelism is up to you. If you want massively parallel, you have to pay for realestate.
    Can't picture how frogger fits into it. FPGA's like GPUS are good at simple & pipelined.Sort of depends on which tool you choose.
    With people selling FPGA add-on boards to go with devkits & such, I'd guess there are a lot of introductions out there now.
    One thing about FPGA tools, is some, especiialy for linux are free & the included simulator lets you get the experience without any money down.
    Also finishing the design in the simulator first, lets you see what size you need to buy to get he space & speed you want.
    Never quite sure where you are going: Thought of mining bitcoins?
    ratstar and Harald Kapp like this.
  3. Bluejets
    Bluejets
    4,599
    976
    Oct 5, 2014
    Quite a few with the same thoughts I think.
    ratstar likes this.
  4. ratstar
    ratstar
    478
    18
    Aug 20, 2018
    Thanks for the reply's.
    If you would be so kind could you point me to a freeware FPGA IDE for windows?
    I've wrote a few virtual machines before myself, so I know what its like, but something that works for real I havent done yet.
    If I can run alot of chess games in parallel, the computer ends up being able to play it by itself. I'm doing something along those lines, and the GPU performance doesn't cut it anymore, I need something more powerful.
    The smaller I can make the individual "core" the more I can have running simultaneously, that could get my core count higher.
  5. bertus
    bertus Moderator
    1,603
    635
    Nov 8, 2019
    ratstar likes this.
  6. ratstar
    ratstar
    478
    18
    Aug 20, 2018
    That looks quite intimidating, is there something easier like a unit to buy thats already assembled and then u just write the code for it? (similar to purchasing a gpu for example.)
  7. Harald Kapp
    11,145
    2,543
    Lots. Google FPGA development board.
    ratstar likes this.
  8. bertus
    bertus Moderator
    1,603
    635
    Nov 8, 2019
    ratstar likes this.
  9. ratstar
    ratstar
    478
    18
    Aug 20, 2018
    So, what makes one fpga worth picking over another, theres alot to choose from there.
    I want->
    * lots of space to put program logic
    * I only want very little ram or state space.
    * I require only a small amount of input and output to and from the FPGA.
    * Id like a fast HZ.
    Is there anything that fits those specifications. (But I don't know what I'm doing yet at all.)
  10. ratstar
    ratstar
    478
    18
    Aug 20, 2018
    Maybe I'm making a mistake, when would an FPGA be desirable over a GPU? cost effectiveness wise, I just don't even know how to begin... because I could just keep going with GPUs and already know the performance I'm going to get, but with FPGA's is it about the same for cost? Because then there would be no point in shifting over.
  11. Nanren888
    Nanren888
    455
    132
    Nov 8, 2015
    If you have a budget: AWS? - instantiate any size machine that you need. :)
    ratstar likes this.
  12. Harald Kapp
    11,145
    2,543
    Do you realize the difference between an FPGA and a GPU?
    A GPU is a special purpose processor but nevertheless a processor. Typically with lots of processing units (shaders) it can be programmed in a dedicated programming language (shader language).
    An FPGA is not programmed to execute code as a processor. An FPGY is a collection of hardware units (cells) that are programmed to perform a specific task an also the connections between the cells are programmable. That means an FPGA is essentially a piece of fixed hardware once it is programmed (of course the programming can be changed and thus the hardware represented by the FPGA - but usually not on the fly, a reset is required to load a new configuration.
    Having the FPGA represent a piece of dedicated hardware with lots of parallel operation performed simultaneously is what makes it so fast compared to a program running on a processor.
    You won't get that. Generally the more computing cells there are within an FPGA, the more I/O pins the chip has. I know of no chip with high number of cells but small number of IOs.
    Possibly the quickest way at the time being. It will take some time to understand FPGAs, the different options you have with them and write efficient code. But if you don't start, you will not reap the benefits from FPGAs. Imho using a starter kit is the best option to get you going. FPGAs will (maybe with exceptions) generally come in hobbyist-unfriendly cases (BGA) and sometimes require sophisticated power supplies (multiple voltages, power sequencing etc.), all of which is dealt with when you buy a starter kit.
    How come you want to look into FPGAs? These are MOSFET based. From your previous posts I got the impression that you are no fan of these. Why not use your super secret, super high speed DIY computer you've been hinting at in previous threads?
    Martaine2005 likes this.
  13. ratstar
    ratstar
    478
    18
    Aug 20, 2018
    Cause I'm impatient, and I need things sooner. I dont mind transistors as long as I didnt need to fabricate them myself, I had a real banger of an idea just not long ago tho, with spark gap based transistors. (You set up the arc with hivoltage low amp over the gap, and then it continue's to arc with lower voltage high amp.)
    Making my own computer from scratch definitely seems like the real cost saver... But I'm judging things way too early, Ive got heaps to discover yet about fpgas...
    Thats a bit of a shame, Because if u reduce the ram and state and I/O, it should reduce the overall machine, If I plugged that into the FPGA id be wasting 75% of whats there because it's not designed for it.
  14. bertus
    bertus Moderator
    1,603
    635
    Nov 8, 2019
  15. ratstar
    ratstar
    478
    18
    Aug 20, 2018
    I was watchin Felix's magic FPGA tutorials. and it actually looks to me like they are better than GPUs by a mile... just need to wait a bit... I feel a bit bad that I wasted my whole life with GPUS right now... *face palm*
    It looks to me i can get a $100 FPGA do better than a GTX3080ti for $2000.
    wth.
  16. ratstar
    ratstar
    478
    18
    Aug 20, 2018
  17. Harald Kapp
    11,145
    2,543
    Be careful. Study in detail what a CLB is. This differs from manufacturer to manufacturer and between FPGA families. A CLB is definitely way less than a shader unit in a GPU. I don't know what you are comparing but this comparison definitely would be nonsensical. Have a look at e.g. this discussion.
    Before you dismiss GPUs, you need to get a grasp on what an FPGA is and what it can do - and what not.
    ratstar likes this.
  18. bertus
    bertus Moderator
    1,603
    635
    Nov 8, 2019
    ratstar likes this.
  19. ratstar
    ratstar
    478
    18
    Aug 20, 2018
    Ok, I'm ready to start simulating, but I dont know what simulator to get.
    Id like it to be VERILOG. but I dont know what program to get, Bertus can u help me plz?
