kelvin_cool_ohm said:
I'm curious about the Chicago Electric motorless generators
including the PTO ones. I want to run one from a waterwheel.
Anyone?
TIA
Rick
Harbor Freight units are the same ones you see on cheap packaged
generators at CostCo or Walmart. All of the ones I have seen are
resonant field units, and can have problems with motor loads. This is
not as much a problem when driven from a water wheel as you will need an
active load to keep the output at 60 Hz, or 50 Hz as the case may be.
Most cheap units are 2 pole, and must run at 3600 RPM. For a water wheel
turning 20 RPM you will need to make up a drive system with about a
180/1 ratio. This drive will have to be efficient, reliable, and low
maintenance. The ideal generator would be a 4 or 6 pole unit with an
active regulator that would have voltage track RPM up to the design
output frequency. This unit may cost two to three times what the HF
units cost.
