Anyone has Datasheet of VT542SRI-4 ?
arvimg
Feb 7, 2017
7
Feb 7, 2017
7
Hello !
I am unable to find the datasheet for VT542SRI-4. It's basically a 4 digit seven segment display.
Out of the datasheet , I majorly need to find drill size for its pcb layout . Please help.
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Can't you just measure it?
arvimg
Feb 7, 2017
7
Feb 7, 2017
7
I'm not equipped with instruments to measure such small measurements and I would like to be precise as well. Moreover I need other data related to it as well. If anyone can manage to find the datasheet ?
(*steve*)
25,510
25,510
The spacing is more important than the size of the hole.
I've looked, but I can't find the datasheet.
(*steve*)
25,510
25,510
Is the spacing clearly something other than 1/10 inch?
davenn
14,260
14,260
Yeah spacing i have noted.
Anyway thanks.
Steve and I don't understand why you are having a problem ..... drill a 1mm and a .5mm hole in some other bit of scrap board and test the fit with the pin of the display
use a smaller drill bit if needed say a 0.25mm
you seem to be intent on making an easy 5 minute test a nitemare ... it's taken you 48 hrs so far and you haven't achieved anything
arvimg
Feb 7, 2017
7
Feb 7, 2017
7
I did such a thing just after sometime of posting the question. I also had to give the datasheet to other team members...So.
Anyway, thanks for showing concern about how much i have achieved.
