I
Impmon
I ripped one out of a non working video camera and from what I can
tell, it only needs 3 lines to display video.
http://personalpages.tds.net/~wilykat/samples/DSC03883.JPG
The white connector visible goes to the camera. From left to right,
pin 1 goes to K of LED and no where else so it's probably only used
for record activity. Next pin, the trace goes only to an IC on the
other side of the board. The last 2 are GND and Vcc respectively.
Few diodes, few caps, few resistors, and a transistor, nothing else on
the bottom. The transistor is probably the HOT
http://personalpages.tds.net/~wilykat/samples/DSC03884.JPG
top side of the board. The IC seems to be used for synch separator
and video to drive the CRT. 4 wires from the bottom of the picture
goes to 2 sets of yokes. 4 wires from other connector goes to the end
of CRT, probably for filament (2), cathode, and grid. The thic wire
goes from the front of the CRT to a little silver box, a transformer
likely.
IC is marked BA7149F / 023 121
http://personalpages.tds.net/~wilykat/samples/DSC03885.JPG
shows the whole CRT.
SO any idea what voltage is Vcc? 5v? The datasheet I found for
BA7149F doesn't specify power supply voltage but it looks to be 5v,
probably max 5.5v.
likely.
probably max 5.5v.
