anybody parting out a pioneer sd-p5075 projection t.v.
Discussion in 'Electronic Repair' started by rico, Mar 6, 2007.
  1. rico
    rico Guest
    I need the high voltage board, part #awv1383. I had a technician look a
    my t.v. and he said I needed the high voltage board. I have checked wit
    pioneer and they are selling the board for $500.00 dollars. Wo
    expensive!!! Maybe somebody has a t.v. they are parting out. Thanks
  2. Don't get a high voltage board, get a new technician.
    Unless the board is badly broken or burned, the tech will diagnose the
    problem and replace the defective components on the board.
    He/she will also check the rest of the set for shorts or other problems
    so the new parts don't burn up.
    If you just buy a new board and put it in and turn it on, the new board
    may go up in smoke costing you hundreds of dollars!
  3. James Sweet
    James Sweet Guest
    What's wrong with the HV board? I've fixed a couple of these, one had
    lots of cracked solder joints, another had a shorted transistor in the
    HV regulator which was causing the voltage to shoot up and trip the
    protection.
  4. rico
    rico Guest
    The tech came and looked at my t.v. He tried to resolder but it did no
    work. Then he told me that its common for this type of board to go bad
  5. James Sweet
    James Sweet Guest
    Must not be a very good tech, there's not really anything irreplaceable
    on that board.
