Could you possibly show me a picture of what this antenna design looks
like? I'm not exactly sure from your description - and I'd just like to see
if it would work with my current design. I hadn't really thought that the
antenna would be a problem!
Try searching on Magnetotellurics. I can find a picture in electronic
form.
Basically, the core is a stack of sheets of Metglass with a very thin
plastic between sheets. Each sheet is about 3" by 36". Don't cut
yourself!
Onto this core many turns of finish wire are wound. Over this a insulator
layer is placed and then many-many-many turns of fine wire is wound. The
huge number of turns converts even lowish frequencies to modest impedances
for the input to an amplifier. The coil with merely many turns is a
feedback winding. The output of the amplifier drives this with a
current. This way the frequency responce of the whole thing is made
fairly flat. Modern systems like this outperform high temp. SQUIDs above
about 1Hz.
