Any wide range input VDC ATX power source?
Discussion in 'General Electronics Discussion' started by carlose.morais, Oct 10, 2013.
  1. carlose.morais
    carlose.morais
    Oct 10, 2013
    Hi folks.
    I need help. I need an ATX power source but it has to mach some specifications.
    It should be 150W and should have an input range from, at least 19 to 60VDC, in other words, a combination between an 24 with ans 48V power sources
    I was reading at this file that they exist but I did a deep search on google and all catalogues I have here and nothing.
    http://www.psma.com/sites/default/files/Wide Input Voltage Range in DC Systems.pdf
    Anyone knows a power source with those specifications or a good website to search for them??
    Cheers. Wink
  2. pebe
    pebe
    83
    11
    Sep 3, 2013
    Do you mean an output range of 19 to 60VDC?
  3. carlose.morais
    carlose.morais
    Oct 10, 2013
    No, the input.
    As it´s an ATX, it´s output doesn´t change the value is it different for each pin.
  4. pebe
    pebe
    83
    11
    Sep 3, 2013
    I thought the input to an ATX was specified as 110v or 240V nominal.
    My error.
  5. davenn
    davenn Moderator
    13,903
    1,971
    There are small ATX PSU units available that have a 12VDC input
    I have used these in a couple of projects
