Some ideas that may help you. Some have been used successfully winding
smaller toroids.
Use a 'throw away' tie wrap to give you a handle with which to hold the
core.
You can clamp the tie wrap in a fisherman's fly-tying vice and position the
core in a convenient position, with the hole horizontal.
Pre-cut wire to length needed. (calculate amount needed or estimate from a
trial run using short piece of wire). Better to end up with some excess,
rather than too short. Use the 'average length' for a turn. Average turn
length will be the average between the minimum length (a turn snug against
the core) and the maximum length (pad the core to simulate maximum number
of turns of wire already wound).
When winding, pass half your wire through center of core.
Then alternate winding turns with each end of the wire.
Pull each turn 'tight' so you don't run out of room for the wire.
Be careful not to pull too tight and damage the insulation on the sharp
edges of the core. You may want to remove the sharp edges with a file or
the corner of a whet stone before you start winding your wire onto the
core.
You can use a short section of thin tubing, such as that salvaged from an
old telescoping antenna, as a 'needle' to push/pull the ends of the wire
through the center of the core if the wire isn't stiff enough to serve as
its own needle.
Start with the wire doubled if you want to wind 'two windings' of the same
number of turns.
bz 73 de N5BZ k
please pardon my infinite ignorance, the set-of-things-I-do-not-know is an
infinite set.
[email protected] remove ch100-5 to avoid spam
