E
Electric dabbler
I've restored a 492 back to life after re-building the power supply. The
analyser seems to work except I'm not sure about the Time/Div control. When
I set time/Div to Auto, the unit seems to work fine with the sweep rate
changing as I adjust Bandwidth Resolution. If I set Time/Div manually the
display looks normal except there is an exact replica of the wanted signal
to the left of the display as I adjust the centre frequency these two
signals merge then cancel out. Is this normal behaviour?
I have service manuals Vol 1 & 2 , was there also a separate instruction
manual for this instrument.
Any advice or personal experience with these instruments would be welcomed.
Many thanks,
Philip
Many thanks,
Philip
