any substitute ofr JK flip flop??
Discussion in 'Electronic Basics' started by Ankur, Feb 23, 2004.
  1. Ankur
    Ankur Guest
    After lot many attempts , i m unable to use the JK flip flop .. don't
    know wht the problem is !
    neways, i wish 2 get something which has a control input and toggles
    at the falling edge. Is there any other device/circuit through which i
    can achieve this ??
    (Pls tellme those which require lesser no. of components as i m
    running short of breadboard space)
    TIA
    ankur
  2. CFoley1064
    CFoley1064 Guest
    Subject: any substitute ofr JK flip flop??
    Unless you're running short of patience, you might want to give that J-K FF
    another try. You don't indicate what chip you're using, or what your power
    supply voltage is, so we're kind of in the dark. Here's what to do to make a
    74HC76 act like a toggle FF with NGT clock transitions: (read in fixed font or
    use M$ Notepad)
    J-K FF Set as a Toggle FF
    VCC
    VCC |
    + .-----o-----.
    | | Set |
    '--o J Q o
    | 1/2 |
    | 74HC76 |
    Input Clock | |
    o------------o CLK' |
    VCC | |
    '--o K Q'o
    | Reset |
    '-----o-----'
    VCC |
    The old 74 series pinouts are probably a good choice because of your
    requirement of a NGT clock. If this doesn't work for you, check your pinouts
    -- you might have things wired wrong. Also, the IC might be damaged (believe
    it or not, it does happen!)
    The other J-K FFs have a similar setup, although some like the 7473 and 74107
    have clear only. You could also use a D FF, but on the standard TTL pinout
    ICs, there is usually a common clock for all the FFs. Usually you want a
    little more latitude.
    If you're using the 7476, there are a couple of gotchas -- read the data sheet!
    Also, make sure you have clean, debounced fast rise- and fall-time clock
    inputs -- that can cause major headaches.
    Good luck
    Chris
  3. You can use a DFF ('74, or some such) with the 'Qbar' tied back
    to the 'D' for a toggle. If you *really* need negative edge
    triggering you can wire up the other half of the package as an
    inverter (using the Set/Reset pins).
  4. Lord Erdel
    Lord Erdel Guest
    cant you just invert your input signal?
