any replacement
Discussion in 'Electronic Basics' started by Jack, Oct 15, 2004.
  1. Jack
    Jack Guest
    hi all
    i need six, 2 input nand schmitt trigger gates in a single ic.
    i just don't want to use 2, cd4093 ics. Is there any such ic which i can use?
    thanks for reply
  2. CFoley1064
    CFoley1064 Guest
    Subject: any replacement
    Hi, Jack. Sorry to say, I believe the part you're seeking doesn't exist.
    If you want to use MML (Mickey Mouse Logic), you can kludge together a one-IC
    solution with a 74C14 like this:
    VCC
    A o---|<--o--|H>O- o Q
    B o---|<--o
    created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
    Q is low only when A AND B are high, and there is some hysteresis for the
    second signal to change. It is slower than a standard gate, and there will be
    more space and holes/pads than two ICs. I don't think this is better than two
    ICs, but there it is.
    Use two ICs.
    Good luck
    Chris
