Any PALASM gurus here?
Discussion in 'Electronic Design' started by Rod Wright, Aug 10, 2005.
  1. Rod Wright
    Rod Wright Guest
    I'm trying to use PALASM4 ver. 1.5 to disassemble a jedec file. The source
    of the file is a hardcopy printout which I typed in with a text editor and
    saved as a .jdc file. When I try to disassemble it, PALASM gives an error
    j140 (not a valid jedec file). Here's what's in the file:
    PALASM XPLOT, V2.22 - MARKET RELEASE (11-19-86)
    (C) - COPYRIGHT MONOLITHIC MEMORIES INC, 1986
    Title : Servo Logic Author : none
    Pattern : 3355750-901-105 (serv_lo Company : none
    Revision : Original Date : 08/18/88
    PAL20S10
    BM42*
    G0*F0*
    L0000 1111111111111111111111111111111111111111*
    L0040 1110111101111111111111111111111111111111*
    L0080 1101111110111111111111111111111111111111*
    L0320 1111111111111111111111111111111111111111*
    L0360 1110111111110111111111111111111111111111*
    L0400 1101111111111011111111111111111111111111*
    L0840 1101111111111111101111111111111111111111*
    L0880 1110111111111111011111111111111111111111*
    L0920 1111111111111111111111111111111111111111*
    L0960 1111111111111111111111111111111111111111*
    L1000 0111011111111111111111111111111111111111*
    L3200 1111000000*
    L3210 0101*
    L3214 000000000000000000001010*
    L3238 01*
    L3240 00000000000000000000000000*
    L3266 0000000000000000000000000000*
    L3294 0000000000000000000000000000*
    V0001 0XX111XXXXXNXXXXXXXXHHHN*
    V0002 1XX111XXXXXNXXXXXXXXLLLN*
    V0003 0XX000XXXXXNXXXXXXXXLLLN*
    V0004 1XX000XXXXXNXXXXXXXXHHHN*
    V0005 100000XXXXXNXXXXXXXLHHHN*
    V0006 110000XXXXXNXXXXXXXLHHHN*
    V0007 111000XXXXXNXXXXXXXHHHHN*
    C3729*
    C93F
    Is PALASM sensitive to tabs or some other formatting that wouldn't be
    visible in the printout? Is there an incompatibility between the older
    version of PALASM that generated the file and the one I'm using?
    Thanks in advance for any help.
    Rod
  2. Rod,
    I don't claim to be a PALASM Guru, but the .JED files that my WinCUPL generates
    look a bit different. Aside from the header comment lines, all the data lines
    begin with an *.
    For example:
    *G0
    *F0
    *L0000 ...
    *L0040 ...
  3. Tilmann Reh
    Tilmann Reh Guest
    Invisible in the printout, the files generated by PALASM contain an STX
    character (02h) before the PAL type identifier, and an ETX (03h)
    character between the JEDEC checksum and the file checksum.
    In HEX, these parts would then look like:
    .... 0D 0A 02 0D 0A 50 41 4C ...
    .... 37 32 39 2A 0D 0A 03 43 39 33 ...
    It sounds reasonable that PALASM also need these boundary markers for
    disassembly.
  4. Al
    Al Guest
    Many, many moons ago, I wrote a Pascal program which would convert the
    code into a logic diagram. Unfortunaately, I don't have a copy. Sorry to
    whet your appetite. But maybe you could search for such a program on the
    web. If I did it, I'm sure someone else did.
    I did this for a military program. The customer wanted logic diagrams
    but none existed as the cicuit functionallity was generated used boolean
    equations. No logic diagram ever existed.
    Al
  5. Bob Stephens
    Bob Stephens Guest
    Don't know if it applies here, but I've had problems in the past with
    different compilers formatting JEDEC files differently especially when
    generated from a hex dump. Some programmers dump the entire fuse map, while
    others only show the areas that are programmed, skipping over blank areas.
    You might try different compilers for disassembly. Or burn it into a PAL
    and dump the image to a file for disassembly. Or even run it through
    PALTOGAL.EXE and see what pops out.
    Good luck!
  6. Rod Wright
    Rod Wright Guest
    By jove, that was it! Thanks for the help!
