Any hints/tips for removing a 5x5 ball grid array chip?
N
N_Cook
Removed in good order for re-use that is . No specialised tools available
and I'm not going out to buy any for a once in a year job. I have a few
ideas but have never had to do it in earnest before. There is about 0.05 mm
clearance space between the balls under the chip and about 5 x 5mm in size.
A few minor SM can be removed from the opposite face of the board,
multilayer and about 1mm thick
N
N_Cook
Jamie said:
If you're trying to save the chip.. fab a small chimney to fit the
outer edges to be used to direct the heat on the bottom side. Use a
hot air gun, timer and suction cup puller on the top side..
Knowing the time it takes to heat the solder for proper removal will
help for installing it later on.
For installation, I've cleaned the surface, used solder paste to
tack down the chip. Put the chimney back on and heat up the under side
while pushing down to reflow the joints. The paste helps in rejoining
the joints of course.
I wouldn't recommend doing this on a regular bases but has worked for
me when I didn't have the proper tools at hand..
Btw. I do have a home made ported hot air fixture I made to remove
chips with under body legs. It blows the air on all four sides
horizontal under the chip. The heater element was a little tricky!
Some ideas there. This is a glass? chip web cam CCD , having a go at making
an "endoscope" so just a matter of freeing the CCD. Will not re-use BGA but
individual wires soldered between with some sort of ground plane.
I was thinking of kevlar fibres pushed under in X and Y sense formed into
loops over some cotton wool pad that can be soaked in freezer spray.
Mask off around the underside of the board and blast with hot air while
tugging at the kevlar "strops"
Jamie
N
N_Cook
N_Cook said:
0.05
Unfortunately before demolishing the web-cam I have to use it , minus IR
filter , to make a video for an elctronic engineer friend of mine. He
reckons they would work as a thermal imager and I don't. So will film a
ladder of // 1/3W Rs fed from an increasing voltage, monitored with DVM in
video, up to the point of charring.
Anyway preliminary testing of procedure works. I could get a doubled up loop
of 0.09mm wire under the CCD so more than I thought the other day. Needle
threader fashion, to pull doubled up kevlar cord back through. About 0.01mm
strands from optical fibre data cable, a nominal 10 to 20 strands run down
with glue to make it handleable, otherwise its like trying to manipulate
candy floss. Usually with SM IC removal I can tension up the strops to some
point less than them breaking so it hardly needs much hot air to release the
IC. But as glass encapsulation this time, will have to be less tension ,
compounded by having to heat from the reverse side. On further
consideration, as heating is on reverse and low extraction force, probably
only need to wire under for strops.
Tensioner is just rubber O ring and standard elastic bands stretched over a
wooden and plastic "gantry" , passed through some felt to protect when
released and also trap the chip if it should shift from the strops. Mat of
multiple layers of GRP woven glass mat high temp glued together , with a
hole punched through, is the mask on the heated side
N
N_Cook
I tried ladder of 7 // from 100 to 330R and stepped up from 1V to 10V by
0.5V steps until the 100R started to smell, overheating. Video showed no
observable difference to any of them
Similar threads
A
Replies
Views
987
A
Replies
3
Views
2K
jrshedden
M
Replies
6
Views
2K
markus wolfgart
M
H
Replies
11
Views
1K
Ron(UK)
R
