Any help in PCB Wizard without item
Discussion in 'PCB Layout, Design and Manufacture' started by Barrymons, Aug 16, 2014.
  1. Barrymons
    Barrymons
    3
    Jul 25, 2013
    Hi all
    Does any one know how i can add a component in PCB Wizard. My schematic is finished but I need to add the component L298 dual full bridge driver but the component cannot be found in the library, I tried adding a component but failed, If any one can shed some light on this issue I would be very grateful.
    Thank you
  2. Harald Kapp
    11,986
    2,808
    Sorry, I can't help directly. Indirectly you could use any other component with the same layout/geometry and connect it as required into your schematic to be able to do the artwork. The schematic will look awkward and unintelligible, but at least you can continue working while you are on the lookout for the correct library element.
