A
Adrian Tuddenham
Fred Abse said:It's really just a logarithmic way of expressing a ratio.
As are nepers.
Bels (and dB) are specifically defined as logarithmic ways of expressing
a ratio of power, not of anything else.
However:
1) As power measurements are more difficult to make than (for instance)
voltage, current or sound pressure, it is permissible to use the easier
measurements if they are known to be related to power. Thus it is
possible to measure two voltages and compare them in "dB" if they were
measured sequentially at the same point in the circuit. You are not
really comparing the voltages, only the power they are developing. It
is also reasonable to use the dB to compare voltages in two different
circuits if they have the same impedance. It is not correct to compare
two voltages across different or unspecified impedances in dB.
2) Logarithms may be a convenient way of dealing with large ratios in
other measurements, such as voltages in different impedance circuits;
but, if "dB" is used, the unit must always be correctly suffixed to show
that it is not a true dB, only a convenient application of the
logarithmic principle.
3) Decibels cannot be used as an absolute unit, but can be used to
compare a power measurement (or power derived fom some other
more-measureable unit) with a particular reference power (1 milliwatt in
600 ohms, threshold of hearing etc.). Once again an appropriate suffix
is needed, to show what reference unit its being used.
