A
Adrian Tuddenham
Tim Williams said:Question: since you've established the goal is characterising an existing
speaker and its acoustic environment, shouldn't the test be performed with
period equipment? Or, given the availability and known limitations of
that, then a modern equivalent designed to emulate key features?
If they're going for historical accuracy, I expect the original
installation contended with the same wire length already, plus a tube amp,
evidently one without the benefit of NFB by your description (typical
triode amps achieve a damping factor of about 3, not counting the
transmission line of course). You should be adding resistance, quite a
bit by modern standards.
I'm sure you've already belabored all this to the client, so I'd just be
curious to know the reasons behind it.
The performance of the loudspeaker is my client's main interest. We can
investigate whether it changes with driving impedance at a later date,
but extablishing the starting point, uncluttered by other variables, has
to be the first move.
Although we know the circuits of two out of the three original
amplifiers (different amplifiers were used at different times), we are
missing key data such as output transformer ratios and construction.
With triode output valves and no overall feedback, the transformer ratio
is going to have a big influence on the output impedance and general
performance of the amplifier.
