Joerg
Fred said:Joerg a écrit :
Then it holds, if you're lucky.
But in this case it would cook out. Must ramp down quickly after the
relay is engaged.
Seriously, with a pair of switches you could do that but I just realized
you want hold from brief to, hum, hours...
You could still make your coil supraconducting
Where's your load (coil) attached?
That's still up to me. Luckily ...
If it's to the supply line, then you could use the ubiquitous 3842/45
Enough pins to coax it to do what you need and I've used it in nearly
the same app.
I am still looking at switchers but these are only 1A abs max and the
30V limit is a bit borderline for me. Really nice would be something
from LTC because they provide SPICE models. However, none of their
synchronous bucks seem to go to 40V or so (for safety margin) and
several amps. Unless you use one with external FETs but then I run out
of room.
