Antique Motion
Discussion in 'Security Alarms' started by [email protected], Oct 21, 2007.
  1. Guest
    I got called to replace 3 Aritech PIR on a Radx 8112. Both as old
    as my Grandfather. I need somebody to clue me in on the wiring for
    this. it has a terminal strip 1.Black 2. Red 3. Red 4. Green 6. White
    and Red wire both in postion 6. 5,7,8 have no wires going to them.
    Obviously 1/2 Should be power 3/4 guess would be the loop from the
    popit 6. With the red wire and white wire is lost me. Maybe a tamper?
    Can somebody please clue me in? Thanks
  2. Guest
    It is a Aritech PR569 Ceiling Mounter Detector.
  3. Nomen Nescio
    Nomen Nescio Guest
    I don't mean to be unkind, but don't you have a meter? It should take you
    less time to meter it out than to type in your question.
    For what it's worth, the standard wiring for Aritech detectors is: 1=
    negative, 2=positive, 3=NC, 4=C, 5=NO . I hope you understand what an 8112
    zone is supposed to look like.
  4. Guest
    Allow me to tell a story. Yes I have a Meter. I certainly am not use
    to working on a 8112. So the story is I work with a Nut case. He
    called me to get the info off of the Motion. I suggested checking it
    out. He refused said NO!! Get the model number and order new ones!! No
    he is not my boss. the part that got/get me is the white wire with the
    red wire under the same terminal. I guess it must be a tamper? Thanks
    for the replies guys.
