"Anti static" mats
Discussion in 'Electronic Design' started by Nemo, Feb 4, 2013.
  1. Nemo
    Nemo Guest
    I got a "static dissipative" mat and measured its resistance between two
    points. On the underside, which is black, it's just kilohms. But on the
    top surface it's too high to measure - I checked the DVM with a 50Mohm
    resistor and it measured 51M, so I trust the DVM. I asked the
    manufacturer how this insulating surface is meant to prevent static
    building up and damaging components... tellingly, no answer was
    forthcoming, "we'll, uh, get back to you".
    I reckon it is possible that these mats work on the principle that
    static flows over surfaces, so it leaks round the edges to the
    conductive layer below. I can quite imagine this being worked out by
    some genius in the 1920s and no one remembers why it works any more:
    "we've always made them that way"; there seems to be an increasing
    number of technologies where the fundamental knowledge is lost. But
    here, the top surface does really seem to be basically a plastic
    insulator. I don't have an electrometer or other handy device to see if
    it holds charge, can anyone reassure me these mats really do work? Or a
    test to prove they do not, like levitating paper after rubbing the mat
    to build up a charge?
    TIA
  2. Ecnerwal
    Ecnerwal Guest
    They are quite well understood, if not by the person in charge of
    fielding phone calls.
    The details are easy to find. As best I recall from when I bought mine
    and actually looked this stuff up (which I'm not going to repeat - you
    can do it yourself) there are problems with using the highly conductive
    side up due to too-quickly discharging things. The more-resistive side
    conducts through to the more conductive side at a moderate but adequate
    rate - the more conductive side keeps everything equipotential.
  3. Nemo
    Nemo Guest
    Thanks. I'll have a go at the electrometer but the responses are already
    reassuring.
    Nemo
  4. gregz
    gregz Guest
    I would use an old VTVM. any deflection can easily be seen. I don't
    remember trying this test. I just believed.
    Greg
  5. There's a 1 meg ohm resistor in the grounding strap that I put one
    when working on sensitive (expensive) stuff.
    (go measure your's)
    George H.
  6. The cleaner is $122 for a spray bottle. What's so special?
    I don't see any resistance specified on that site.
    That site has mats that are $10/sq ft, but most are $100/sq ft with no
    specifics about the difference.
