Antenna Design Question
Discussion in 'Electronic Repair' started by hemyd, Mar 12, 2006.
  1. hemyd
    hemyd Guest
    I need to build a basic TV antenna, "heavy duty" to withstand the weight of
    large birds landing on the elements. Are there any sites which give design
    specifications for TV antennae?
    Thank you.
  2. Michael Ware
    Michael Ware Guest
    Try this site, lots of hams and electronic gurus hang out here.
    www.radioreference.com
  3. Build it? OK, if that is your thing and you don't put a price on your
    labor. But you might be better off buying one designed for cable-tv
    head end use.
    http://www.kathrein-scala.com/vhf-tv_yagi.php
    http://www.kathrein-scala.com/uhf-tv.htm
    http://www.blondertongue.com/reception/Reception.pdf
    http://www.tacocommunications.com/TACO Yagi y10x.pdf
  4. Nick
    Nick Guest
    I do not know if this will help but a good book on Antenna design is
    Antennas by Kraus Published by McGraw Hill.
    I t should be available in the library. The book covers all antenna design
    in detail.
  5. Guest
    Guest Guest
    : I need to build a basic TV antenna, "heavy duty" to withstand the weight of
    : large birds landing on the elements. Are there any sites which give design
    : specifications for TV antennae?
    : Thank you.
    : Henry
    Try getting a copy of the ARRL antenna handbook. Google it or search for one
    on eBay.
    b.
