Antena that can sense thermal Radiation from human body
Discussion in 'Electronic Basics' started by Jiks, Mar 18, 2007.
  1. J.E.B.
    J.E.B. Guest
    I've read some of this dribble, wanted to post a question about some
    basic electronics . Am I in the right place? First post by the way.
  2. J.E.B.
    J.E.B. Guest
    Alright than I'll post the question according to this format: I have a
    monkey butt fucker battery charger rated at scumbag ass 6/ 12vdc 2/4/6/
    amps trying to run a chlorate cell. The brain dead farting thing keeps
    shuting off every couple of seconds. How do I get around this? want
    this scumsucker to run run run.
  3. John  Larkin
    John Larkin Guest
  4. Rich Webb
    Rich Webb Guest
    The "ignore thread" feature in Agent comes in handy too, once in a
    while.
    Wonder what got PA's dander up so badly today. Hangover from too much
    green beer, perhaps? ;-)
  5. Phil Allison
    Phil Allison Guest
    "Gareth"
    ** What drugs are you on - imbecile ?
    A massive overdose of Google Drops ??
    All swallowed whole without a tiny drop of comprehension.
    Who do you think you are kidding - fuckwit ?
    Piss off.
    ...... Phil
  6. Phil Allison
    Phil Allison Guest
    "Gareth"
    ** Thermal radiation at mm wavelengths is emitted by ANY OBJECT you ass.
    The IR spectrum contains more energy and so has long been easiest to detect.
    The rest if the MARKETING craopolgy you posted links to is about mm
    wavelength RADAR !!
    Like I said before - what drugs are you on ?
    ........ Phil
  7. Gareth
    Gareth Guest
    Isn't that what I said in my post at 14:01 on 18 March 2007
    I also said IR was easier, See my post at 14:01 on 18 March 2007
    Did you actually read any of them? The first two are PASSIVE, which
    means that they don't transmit - it's not about radar. The last one can
    be either active or passive.
    http://www.qinetiq1.com/home/security/national_security/securing_national_borders.html
    "QinetiQ developed BorderwatchTM using its patented passive Millimetre
    Wave technology to enable the detection of clandestines."
    http://www.roke.co.uk/download/casestudy/040-pandora.pdf
    "Roke’s solution was to make PandoraTM a passive sensing system using
    radiometry."
    http://www.tadarvision.com/
    "Tadar may be configured as either a passive or active imaging system"
  8. Phil Allison
    Phil Allison Guest
    "Gareth"
    ** All posts appear with local times attached - fuckwit.
    There is no " person " detector.
    ** All marketing PUKE.
    All UTTERLY irrelevant to the OP's question - fuckwit.
    ** Do you see the word ** rest ** ??
    The " rest " is what is left over !!!!!!!!
    ......... Phil
  9. Ok: PLONK
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  10. MassiveProng
    MassiveProng Guest
    You are all lard. With the exception of that ass that you talk out
    of. That is all lard packed full of shit.
    The funniest thing is that I KNOW you are a fat ****. That is one
    of the things that pisses you off, LardTard.
  11. MassiveProng
    MassiveProng Guest
    A battery charger is NOT a DC source, dipshit. It is rectified AC,
    and that is ALL. It also has a thermal shutdown which indicates that
    you are pulling MORE than it is rated at, dipshit. So go buy a 30 Amp
    charger if a charger is all you want, OR...
    Buy a fucking supply that doesn't fold back on itself before its
    rated output is reached, OR do your requirements analysis better and
    realize that you needed a more powerful supply to begin with, you
    fucking retard.
  12. J.E.B.
    J.E.B. Guest
    Thanks for the moronic answer dickhead, Is this the best you assholes
    can muster?
  13. Rich Grise
    Rich Grise Guest
    Most people just ignore PA.
    Cheers!
    Rich
  14. John Fields
    John Fields Guest
    His answer was spot on, cuntface.
    What's a dumb **** like you doing trying to run a chlorate cell
    anyway? Better run over to rec.pyrotechnics and find out how _not_
    to blow yer head off.
    At the very least, get your head out of your ass and Google
    "chlorate cell power supply."
  15. MassiveProng
    MassiveProng Guest
    The name calling was less than required, but the answer was spot on,
    dipshit.
    If you had any brains at all, you would open it up, and bypass the
    thermal switch.
    But NOOOOoooooo!
    You're obviously the fucking moron in this thread.
  16. Brian
    Brian Guest
    JOHN!
    I filter on the word "ass", and it works very good. None of these
    dimwits can ever post without using that word due to their
    homosexuality-based fixation with the male rectum. But when you chop
    out parts of the post and reply, I am forced to see them! So please,
    when you reply to such a post, kindly address the OP as "Mr. Asshole"
    so that my filtering remains solid protection against such deviant ass-
    inclined backdoor turd burglars.
    Thank you.
  17. MassiveProng
    MassiveProng Guest
    You're an idiot.
  18. MassiveProng
    MassiveProng Guest
    Looks to me like the fixation is yours, retard.
  19. krw
    krw Guest
    I assume you get a lot of false positives with your simple filter.
  20. J.E.B.
    J.E.B. Guest
    Thanks fellows, The google key search words (chlorate cell power
    supply) was enlightening. Hope my shitty humor was not to overboard.
