- Joined
- Nov 28, 2011
- Messages
- 8,393
OK. I've just discovered that I've missed something important - the big white relay marked JQX-105F-1. This relay is controlled by Q2 and possibly another transistor next to it (it's covered with white goop so I can't tell), and these transistor(s) are controlled by the daughter board.
So don't worry about the MOSFET and diode measurements at the moment. Also, those devices that detect voltage on a wire by touching the insulation will not tell us much.
I think I will need to follow the circuit of the power supply as far as the daughter board. I need to see a good, well-illuminated picture of both sides of the main board, covering the area shown in dark contrast in the following picture.
For these pictures, please use a fairly high resolution setting, with the camera facing directly downwards on the board. The board needs to be illuminated, but not with a single light source, because that causes reflections in certain areas of the board. Ideally, a bright overcast day, using outdoor lighting, is perfect, but you could get the same effect by reflecting a light source off a light-coloured, rough surface so that the light is dispersed.
I need to be able to read markings and colours on the components, and clearly distinguish the copper tracks on the underside.
Also I'm going to need you to make some more voltage measurements. The rest of the treadmill isn't needed - not initially, anyway, so if you can get AC mains onto the mains input connectors on the board, you can test it stand-alone. You need to be extremely careful doing this, to make sure the board can't move or fall off the table and short out on anything or make contact with anyone, and that the mains connections can't become disconnected and touch onto anything or anyone.
The main reason here is to avoid back-and-forth and disturbing your father-in-law. I know it would be easier if you could do your work by yourself.
