rings or nothing.
I find that it's much mo' betta to be able to mount the keypad to drywall
without a ring that way I can line up the keypad with the lightswitch
below...more visually appealing...because if you put a ring up the keypad is
out of kilter with the light switch below...jmo. Also, I like to match the
height of keypad to the client so they can actually read the lcd.
|I usually use mudrings on keypads during open construction. That is a
single
| gang open face plate that allow full access behind the wall.
| But I think because of all the new building codes, some states now require
| you to use a plastic single gang box. The wire entering the box also has
to
| be fire blocked with spray foam.
| Jim Rojas
| | > Do keypads usually mount to single or double gang boxes? Or do they
| > just typically get screwed directly to the wall?
