S
[email protected]
Hi all.
I am working on a inductor for a boost PFC controller.
How do I calculate what the flux density in the core will be , to
make sure I avoid saturation. The frequency will be 100Khz.
Power level would be 300W. AC is 220V.
The formula for flux density is B = (E* 10^8) / 4.44.N.A.F
The value of 4.44 I assume I would change to 4.0 for a square wave , as
the inductor is bieng switched at 100khz.
The core I have is an MPP core (CM400060) with a Ae of 1.07cm^2 which I
assume is A.
What value should I use for E. Would it be 220 * 1.414 ?
Say there are 105 turns on the toroid.
That would give me a value of 690 odd gauss (69mT ?) . Does this look
correct?
According to the litrature I have , the MPP cores saturation flux
density is about 8000 gause(0.8T). If my calculations are correct this
core is WAY over spec , and I should be able to reduce it significantly
, but I'm sure I'm missing something here.I would like to use a powder
iron core as this is cheaper.
Any help appreciated.
Cheers
Rob
assume is A.
correct?
Cheers
Rob
