Y
Yzordderex
I need to generate two square waves while being able to control the
phase relationship between them. Square waves at 4Mhz. Ideally I
would like to be able to control phase 0-180 degrees, but would settle
for 5-175. I need to vary at audio rate, dc to 8kHz. A phase
modulator if you will. Can a phase lock loop be configured to do the
job? I've got a function generator which will do 10Mhz to aid in
development. If not PLL, then some other off shelf component would be
desired. I have access to coworker very knowledgable with dsp, but I
would like to keep it simple.
thanks
thanks
