Annoying obsolete 44 pin sound chip?
Discussion in 'Electronic Repair' started by conundrum, Apr 17, 2007.
  1. conundrum
    conundrum Guest
    Hi all.
    I've got a PCB here originally from a motorised robot car which
    according to the manufacturers has a blown sound chip. The cpu does
    seem to be working as the i/0 lines are being toggled and the crystal
    is running on frequency, but is not responding to the trigger pins
    even though they are being polled.
    The CPU (whatever it is) has the crystal on two pins near the bottom
    left of the chip, and the sound chip is a 44 pin quad flat pack. It
    looks like the 5v regulator lost its ground pin and applied +8V to the
    logic for an indeterminate time :(
    PCB is labeled ST003 v2 if this helps.
    Anyone seen this fault before? I really do not want to change a £150+
    board for a £3 sound chip! (someone's sanded off ALL the markings grr)
    The sound storage EPROM is a 24C002 (2 megabit) and that looks intact.
    Thanks in advance,
    -A
  2. James Sweet
    James Sweet Guest
    Can you work out the pinout of the chip? Perhaps there's some
    recognizable features that could point you to the manufacture?
  3. hi, some times if you wet ya finger , then wipe it on teh top of teh chip ,
    and use a strong light u might be able to make out some markings, i did
    this to a chip , where the marking s where ground of , but they didnt do
    a proper job.
    mark k
