Angle of view on minidome cameras
Discussion in 'Security Alarms' started by Dave, Nov 4, 2003.
  1. Dave
    Dave Guest
    Hi all,
    What sort of angle of view do you get with mini dome cameras (4 inch
    or 6 inch dome). For example if I mount a dome 8ft high at the end of
    a 100ft hallway, will I be able to adjust the camera high enough to
    see the whole hallway. I 'm not concerning with focal lenght or
    anything, but how far in degrees can these things be turned from a
    vertical, or straight down position?
    Thanks in advance,
  2. mister g
    mister g Guest
    every mini dome i've used - you pretty well get 180 degrees of view in every
    plane
    mechanically the "camera" is mounted on a universal joint arrangement within
    the housing giving full range of movement
  3. Dave wrote
    You will be able to adjust the camera to see the hallway. Since the hallway
    is 100 feet long though, you might want to consider a longer lens than the
    ones (4mm) typically supplied with mini domes.
    js
