Analyzing circuits with tapped inductors
Discussion in 'Electronic Basics' started by M. Hamed, Apr 13, 2013.
  1. M. Hamed
    M. Hamed Guest
    I am currently looking at the Hartley oscillator (yes I'm getting serious about that stuff), and I currently find it hard to analyze circuits with tapped inductors. I thought about treating them as two separate inductors, butthen there is mutual inductance which complicates matters.
    Does anyone know of a good text that does this kind of analysis, possibly with worked examples and preferably in the context of semiconductor electronics ?
    Thanks a million.
  2. Phil Allison
    Phil Allison Guest
    "M. Hamed"
    tapped inductors.
    ** The Hartley oscillator will operate with independent inductors.
    I thought about treating them as two separate inductors, but then there is
    ** With independent inductors in series, the impedance ratio determines the
    voltage ratio at a given frequency.
    With a tapped inductor, it is the turns ratio that does it.
    .... Phil
  3. M. Hamed
    M. Hamed Guest
    Phil, to analyze as series inductors, doesn't that assume the current going into the tap is negligible? Is it always a safe assumption?
    For example in this circuit, http://www.mathworks.com/matlabcentral/fx_files/20391/1/Hartley.JPG I couldn't really figure out why I can assume there is small current going from ground into the tap. Thanks.
  4. Phil Allison
    Phil Allison Guest
    "M. Hamed"
    ** Not possible if the inductor **IS* in fact TAPPED.
    ** Because I posted a reply to your question does NOT mean you can turn
    around and ask me anything you like.
    ALL questions MUST be posted to the group, unless you only want
    clarification of what some poster has said.
    Usenet 101 - pal.
    ..... Phil
  5. Jamie
    Jamie Guest
    I don't know what spice program you're using, if you are using one at
    all, but with LTspice the L value also reflects the turn ratio.
    There is another L model in Ltspice you can use which will allow you
    to better specify the coil properties. Just look at the help file for that.
    If there is a way to do this with a directive using the default L
    model to specify turn ratio, I don't know what it is. Maybe a LtSpice or
    spice in general expert can answer that question. I had to use the other
    model one day to do what I needed. (John Chan) model, that allows you to
    specify the turns with out changing my L value.
    Jamie
  6. Fred Abse
    Fred Abse Guest
    Two inductors, which are magnetically coupled go as:
    Ltotal = L1+L2+2*M, where M is the mutual inductance, one to the other.
    Where coupling is unity (like two inductors wound on a common core which
    has very low magnetic leakage, toroid or pot core for example),
    M=sqrt(L1*L2).
    Hence, for tightly coupled inductors, Ltotal = L1+L2+2*sqrt(L1*L2).
    This brings us to the concept of coupling coefficient, K, which is
    commonly used in SPICE analyses. It is simply M/sqrt(L1*L2), which is
    always <= unity.
    If you are interested in voltage ratios, it is easier to work with turns
    ratio. V1/V2= N1/(N1+N2), for a tapped inductor.
    Bear in mind that inductance is proportional to turns squared.
  7. Fred Abse
    Fred Abse Guest
    More accurately the turns ratio squared. L1/L2=(N1/N2)^2
    The Chan model requires a knowledge of the core hysteretic properties:
    The parameters Bs, Br, and Hc define the permeability of the core, with
    respect to the magnetizing force, H. L is then derived from that, the
    number of turns, the magnetic path length, the effective area, and the air
    gap.
    For an air cored coil, Bs is infinite, Br=0, Hc=0, Lg=Lm. Hence the Chan
    model is not suitable.
    The inductance of an air cored solenoidal coil depends not only on turns
    squared, but on its diameter, length, and winding pitch.
  8. Phil Allison
    Phil Allison Guest
    "Fred Abse"
    ** Put far more simply, if you measure the overall L figure and you have the
    turns ratio at each tapping - the L value of each tap goes as the square of
    the turns ratio.
    Egs:
    For a centre tap L = 1/4 of the total L.
    For a 10% tap, L = 1/100 of the total L.
    Too simple.
    .... Phil
  9. Fred Abse
    Fred Abse Guest
    Quite so.
  10. M. Hamed
    M. Hamed Guest
    Noted. That wasn't my intention though.
    That was just a misunderstanding of what Phil said about series vs. tapped inductors.
  11. M. Hamed
    M. Hamed Guest
