James
On our kit car, we have a speedo using an old mechanical setup (spinny
magnetic disk) but as we are going to be changing gearboxes, diffs and so
on, I want to turn it into an electronic one.
I basically envisage a reed switch operated by a magnet on the propshaft
that feeds a signal to a circuit that will then drive a stepper motor/servo
to turn the dial. Obviously it will need some form of calibration, but this
can be as simple as a tweakable variable resistor combined with trial and
error comparing to a GPS, I don't need a fancy device where you set
diameters of wheels and it works it all out (although if its simple then
great!)
So, I assume the pulses will feed a freq-voltage convertor and this will
then operate the motor to turn a set amount from rest for a rising voltage,
presumably some sort of feedback required there? I think i have the theory
down OK, but I could do with some circuits- any on the net that people have
found that I can work from?
Also, replacing our mechanical bits will involve losing our odometer... I
imagine this is more complex to make so not worried immediately, but any
examples of these will be handy also.
Free ride in the car to all who help! (If you live nearby....) )
TIA,
James
great!)
TIA,
James
