S
[email protected]
I am currently involved in a project, part of which is to design an
analogue FM system which will accept a 20kHz - 200kHz modulating
signal. This signal will also occur over several orders of magnitude,
but will be used with a time programmed gain circuit in order to level
out the modulation input.
I see most of the posts are related to audio FM, hence much lower
modulation frequencies, but is there any limitation on the bandwidth of
the modulation signal for standard FM circuits? Are there off-the-shelf
ICs which would facilitate this application? If not, what would be
considered the 'best' design for such a system? The system need not
transmit more than 10 metres or so, but must be as small as possible -
so component count is important, and quality may be sacrificed in order
to maintain a small, light design. This factor is the reason why a
digital design is not being considered.
Any suggestions and help much appreciated, this really isn't my area of
expertise. Apologies for any lack of detail...if more information would
be useful, please ask.
Simon.
Simon.
