Analog voltmeter question - minus DC voltage
Discussion in 'General Electronics Discussion' started by Dust bunny, Feb 21, 2013.
  1. Dust bunny
    Dust bunny
    10
    Oct 4, 2012
    I need an analog panel mount voltmeter that can show a minus DC voltage range of approximately -500mV to -1500mV
    I read however, that an analog voltmeter cannot display minus values. Is that correct?
    If it is, can I just reverse the polarity of the connections to a say, 2 volt voltmeter?
    Many thanks!
  2. Jotto
    Jotto
    120
    Aug 24, 2012
    I have a meter that can read both positive and negative without changing anything. So I would think there are other meters that can do the same thing, you will need to search it out.
    I am talking a analog meter, not a digital. You should be able to get a digital one also.
  3. Harald Kapp
    11,963
    2,798
    Google "voltmeter center zero" (without quotes) or go here.
  4. BobK
    7,682
    1,688
    Reversing the leads will be okay as long as the meter has no other connection to the circuit.
