Analog meter repair
Discussion in 'Electronic Repair' started by Eric, Sep 15, 2003.
  1. Eric
    Eric Guest
    Do anyone know where can I get rewire my 1960 tube tester's voltmeter, is it
    very expensive?
    Thanks for the help and information.
    Eric
  2. Sofie
    Sofie Guest
    Eric....
    It might be cheaper and easier to find a old, used (same model) tube tester
    on ebay or a garage sale... it doesn't have to be in working condition or
    in good cosmetic appearance .... just the meter has to be good.
  3. I would absolutely agree with this. Rewinding a meter is virtually
    impossible.
    --- sam | Sci.Electronics.Repair FAQ Home Page: http://www.repairfaq.org/
    | Mirror Site Info: http://www.repairfaq.org/REPAIR/F_mirror.html
    Important: The email address in this message header may no longer work. To
    contact me, please use the Feedback Form at repairfaq.org. Thanks.
  4. jakdedert
    jakdedert Guest
    Ditto all of the above...EXCEPT if it's a TV-7. There was a discussion on
    rec.antiques.radio+phono last week about someone who performed this very
    service.
    Google Groups.....
    jak
  5. James Sweet
    James Sweet Guest
    Is the coil actually burned up? Rewinding it would be hopeless, but it may
    be that the wire has simply broken off and can be repaired. I've fixed a few
    speakers this way where the voicecoil wire broke right where it connects to
    the flexible lead in wires, it wasn't easy but it's lasted so far.
  6. Apparently it can be done, but this is a job for the very, very few...
    For the ones of you who read German, take a look here in
    Dieter Wächter's article, how he wound a new moving coil
    for a TV-7A/U with #50 wire (0.025 millimetres thick!)
    Here is the link:
    http://www.jogis-roehrenbude.de/Roe...uefer/TV-7-Restauration/TV-7-Restauration.htm
    Stein
  7. Sofie
    Sofie Guest
    Stein-Olav Lund:
    Thank you for finding that very fascinating site. I spent nearly an hour
    looking over all of the detailed photos and the photo-diary progress of the
    TV-7 restoration.
    My feelings are that this guy has way too much time on his hands..... he did
    a very nice and thorough job.... and as you pointed out, this is not a job
    that most of us would do, especially the meter coil rewinding...
  8. JW
    JW Guest
    Imagine getting half way through, and the wire snaps. ARGH!
  9. I'll second that. Yike! :)
