Analog Block Nonlinear In Programmable Out
Discussion in 'Electronic Design' started by Harry Dellamano, Aug 16, 2003.
  1. I need a circuit that accepts a nonlinear input voltage, two to four volt range of a thermistor output, and outputs a different nonlinear voltage, two to four range to control a battery charger's output voltage over the temperature range. The voltages are within 15% of each other over the temp range but I need 1% accuracy and operate from -40C to +85C ambient. It will operate in a +5VDC and +12VDC universe.
    Does anyone make an IC that has a 12 BIT ADC front end, programmable ROM and 12 BIT DAC output to do this function?
    What other possibilities are there?
    Hey Win, no designs in AoE that I could find.
    thanks
    harry
  2. Fred Bloggs
    Fred Bloggs Guest
    Something like the MAX1463
    http://pdfserv.maxim-ic.com/arpdf/MAX1463.pdf
  3. Andrew Paule
    Andrew Paule Guest
    Easy way to do this -
    A/D input to address of 12x12 SRAM (3 4 bit parts), data bus of SRAM to
    DAC - need a little glue for a micro to load (will give you control of
    your desired transfer function), pretty standard LUT architecture.
    Andrew
  4. Analog Devices and Cygnal and TI have such devices. They all sport an
    8051 and Flash ROM in a corner of the chip to do whatever you like
    inbetween. If you can live with 10 bit PWM for the output, there are
    other, cheaper, choices.
    Best regards,
    Spehro Pefhany
  5. Harry, is it neccessary to put the whole width of the signal
    through a lookup table?
    Since there is only a 15% error from direct control then it could
    make sense to use direct control anyway and then just have an
    error-corrector, sitting off to one side, summing-in the req'd
    correction to the charger. This reduces the resolution/accuracy
    required from the error-corrector.
    Thermistors and RTDs are linearised with resistor networks,
    and/or tickling the stimulus. There's nothing to say that
    a thermistor cannot be similarly 'non-linearised', so that
    its output tracks the required battery volts with temperature.
    Can you post information on the thermistor tables and the
    required battery volts v temperature?
  6. Fred Bloggs
    Fred Bloggs Guest
    Nah- this single chip solution is so far beyond anything that can be
    done with a conglomeration of separate components that it is pathetic.
    Not only is there a programmable embedded CPU controller, but it also
    has quite a bit of configurable analog circuitry with analog mux's,
    selectable ADC reference source, programmable gain amps, timers etc. It
    also totally HALTs all CPU switching when it goes into ADC conversion
    mode for the ultimate interference reduction. The evaluation kit ,
    MAX1463EVKIT is a mere $99 and requires minimal programming skills- all
    GUI. The CPU instruction set is minimal and straightforward- impossible
    to miss. As for the 4Kb flash memory- note that with the CPU smarts,
    no-one would be so simple-minded as to use it as look-up table for
    12-bit function conversion- it is used to store a FAR SMALLER set of
    coefficients used to COMPUTE the function with the CPU. This design is
    incredible overkill for the app- but the price and simplicity of
    development cannot be beat.
  7. volt range of a thermistor output, and outputs a different nonlinear
    It will operate in a +5VDC and +12VDC universe.and 12 BIT DAC output to do this function?
    Thanks Spehro, Fred and Chris for your digital solutions but as I pointed
    out to Tony, my customer hates microprocessors or digital IC>16 pins. He has
    spent too much money on programmers in the past so an analog solution would
    be preferred.
    regards
    harry
  8. Hi Andrew, I understand the data flow and would like to find the solution
    in one small IC with very little software and no glue logic. The function
    could fit in a 6 pin analog/digital/analog IC but any larger forces me to
    the analog domain and a solution I do not presently have.
    thanks
    harry
  9. Hi Don, thanks for the reply.
    I would like to find the solution in one small IC with very little
    software and no glue logic. The function could fit in a 6 pin
    thanks
    harry
  10. /|\
    |____??
    I never saw the post referred to, so queried Harry directly
    and he kindly emailed the V-batt and R-thermistor tables.
    Harry's going to kick himself, because he was nearly there
    already (with the 2700 ohm R-source for the thermistor) but
    did not take the extra step. :)
    +---------->Vout
    | R-th
    Const-Current +-->-----+--/\/\---+
    1.855mA | |
    2700 |
    ------------------------------+---0v
    The 1.855mA would come from a single opamp Howland
    circuit, or something.
    Temp Batt-mV R-therm // with 2k7 Vout-mV
    -5 4699 41970 2537 4706 <--- +0.15%
    0 4617 32430 2492 4623 <---
    5 4519 25260 2439 4524
    10 4403 19830 2376 4407
    15 4267 15670 2303 4272
    20 4113 12480 2220 4118
    25 3940 10000 2126 3944
    30 3750 8066 2023 3753
    35 3544 6545 1911 3545
    40 3326 5343 1794 3328
    45 3099 4386 1671 3100
    50 2868 3620 1546 2868
    55 2637 3003 1422 2638
    60 2410 2504 1299 2410
    Max nonconformity is 0.015% in the 0 to -5C region.
  11. /|\
    Tony (Typo) Williams strikes again.......
  12. Tim Shoppa
    Tim Shoppa Guest
    I'm a bit confused by apparently contradictory requirement. You say you
    need 1% accuracy, but then say you need 12 bit ADC, which would be
    smaller than 0.025% full-scale precision.
    Maybe you want 0.5% precision to get your 1% accuracy (as you seem to be
    throwing away half your scale in the most naive use of the ADC.)
    Don't write off Flash EEPROM PIC's. You could even customize the nonlinear
    function for each thermistor and load it into the EEPROM at calibration
    time, with the calibration done by the PIC itself (and a help from an
    external linear temperature probe). With a 10-bit A/D (which I think
    could fit your requirements) and PWM for D/A it'd all fit on a 8 pin SOIC
    with a small RC for the output PWM filter.
    Tim.
  13. Unfortunately, there are no 8-pin PICs with hardware PWM, AFAIK, but
    an 18-pin package isn't so bad. It would be pretty trivial to write
    the program. The hardware would be the chip, a few ceramic caps, and a
    couple of resistors, using the power supply for the PWM reference.
    OTOH, Tony's solution is very nice, and appropriate for the task, IMO.
    Best regards,
    Spehro Pefhany
  14. Hi Tim,
    I misspoke on my accuracy statement. I need better than 1% but most ADC are
    12 bits or larger these days which as you correctly point out is 0.025%. A
    10 Bit would be a perfect fit.
    The function could be done in a 6 pin SOIC. 10 bit ADC, EEPROM and DAC. I
    thought that I might get lucky and it was off the shelf but not so.
    regards
    harry
  15. The PIC solution wouldn't be too bad (essentially what you're asking
    for, with VERY LITTLE programming required for the setup, read the
    ADC, fetch from a LUT, and output. < $2. US in 100's.
    But have a look at this:
    +12.00
    | | 482K
    +--------------------o Vcell
    | | 119.9K
    Rt |/| | | 120.7K
    GND
    I get a maximum error of -31mV at -5'C and +20mV at 60'C, which might
    be 1% if you figure error some funny way. You can fiddle the value of
    the 119.9K to center the error if you like.
    Temp Error (mV)
    -5 -0.031
    0 0.032
    5 0.019
    10 0.015
    15 -0.004
    20 -0.009
    25 -0.006
    30 -0.015
    35 -0.008
    40 -0.006
    45 -0.011
    50 -0.003
    55 0.008
    60 0.020
    Best regards,
    Spehro Pefhany
  16. Tim Shoppa
    Tim Shoppa Guest
    But there is so little to do that there shouldn't be any problem using
    the timer and some software to do the same thing.
    At the 1% level maybe it'd be better to use a small 3-pin reference. If
    I'm following Harry's comment about use in a battery charger correctly, 1%
    (or better) really is a good idea.
    Are there any small (8-pin?) microcontrollers with good precision references
    built in?
    Tim.
  17. Sure, but the LPF frequency will be MUCH less. It's possible to get an
    ~8kHz 10 bit PWM timebase with the internal clock on an F819, so a
    simple single pole filter with a ceramic cap could do the trick.
    Sure, or using a cheap regulator (with good stability) adjusting it at
    some point may be cheaper than going with a precision reference,
    precision resistors etc. etc. A microcontroller would allow the
    possibility of digital trimming, at the expense of more programming.
    None that I know of. In fact, there are only three manufacturers of
    such micros that I know of- Motorola, Microchip and Fairchild.
    Best regards,
    Spehro Pefhany
  18. Hi Tim,
    This is for VRLA batteries in an avionics environment, rear of commercial
    aircraft. These batteries are more restricted than lead-acid which can vent
    more readily. The solution looks like it must be analog since <1% looks
    feasible and the minimum software restriction. Size and power dissipation is
    not critical.
    regards
    harry
  19. On Tue, 19 Aug 2003 16:04:23 GMT, the renowned Spehro Pefhany
    Correction to the values and the error table..
    T (°C) Vcell' Error (V)
    -5 2.883 -0.117
    0 2.802 -0.018
    5 2.734 -0.006
    10 2.676 0.006
    15 2.628 -0.002
    20 2.589 -0.001
    25 2.557 0.007
    30 2.531 0.001
    35 2.510 0.010
    40 2.493 0.013
    45 2.479 0.009
    50 2.468 0.018
    55 2.459 0.029
    60 2.451 0.041
    Not so good, especially at low T, but between 0 and 55° it is
    within about +/-1% of cell voltage.
    Best regards,
    Spehro Pefhany
  20. Sorry about that Harry. I thought volts/cell was nearest
    the '4.699' and started from there. Ok, back to the
    drawing board.
