AN5551 pin out
Discussion in 'Electronic Repair' started by [email protected], May 13, 2005.
  1. Guest
    Brett said " anyone know where I can find the pinout of IC AN5551. From
    what I can see, this is a generic IC. It came out of a Hitachi TV.
    Tried a search at NTE but no cross. Trying to determine if this thing
    is causing my horizontal output to blow. Pin 9 only had 1.2Kohm to
    ground, but there is a 5.8kohm resistor off this pin to ground.
    Resistor is good. Thanks all."
  2. Doug
    Doug Guest
    Go to www.bdent.com
    you may have to register . free.
    otherwise post you e-mail and I'll send it to you.
    The data sheet just shows block diagram of the inside.
    Doug
  3. Guest
    Thanks Doug. My e-mail is .
