An Article: An Introduction to Power Factor
Discussion in 'Electronic Basics' started by KodKodKod Learning Consulting, May 16, 2006.
  1. Phil Allison
    Phil Allison Guest
    "KodKodKod Learning Consulting"
    ** Unreadable.
    Spam overwriting text and text overwriting test.
    Horrible.
    Plus you have not quoted the basic definition of Power Factor.
    Do YOU even know it ???
    ........... Phil
  2. flank
    flank Guest
    This need a lot of work.
  3. If the reader knew enough to understand the first equation, they
    wouldn't need the article. You do not define imaginary current, nor
    power factor (in a general, conversational) way before you launch into
    math. The math should quantify what is first understood,
    conceptually. Your approach also does not include harmonic power
    factor, but only phase shift power factor (without hinting that it is
    covering only one of two possibilities).
    Do you need a consultant?
  4. John Fields
    John Fields Guest
    We?
    It's still crap.
    _You_ keep pretending that you're an authority of some kind, but you
    still don't seem to really know the difference between reactance and
    resistance.
  5. John Fields
    John Fields Guest
  6. I still think you need to start with a question (the opening
    "question" is just a phrase) and say what displacement power factor
    is. The current drawn by a reactive load has two components. One is
    power consumed by the load (or converted to some of the form of power,
    like mechanical). The second component represents energy that is
    stored by the reactance and then returned to the power source, twice
    per cycle. So the line current represents power passing one way, from
    source to load, and also energy sloshing back and forth between source
    and load as short term loans. The combination of both energy flows
    produces relative a phase shift between the line voltage and line
    current.
    If the reactance is inductive, the energy is borrowed mostly after the
    voltage peaks so the current peaks lag the voltage peaks. If the
    reactance is capacitive, the energy is borrowed mostly on the way up
    to the peaks, so the current peaks lead the voltage peaks.
    Then the math shows the details of these processes.
  7. Phil Allison
    Phil Allison Guest
    ** STILL Unreadable !!!!!
    Spam overwriting text and text overwriting text.
    Horrible.
    ........... Phil
  8. The Phantom
    The Phantom Guest
    The first line (in red) isn't a question, as JP points out.
    I think your page is aimed at beginners, and therefore you should avoid
    the exponential notation; stick to simple SIN(wt+theta) notation.
    Regarding the reference you give at the bottom; what is PAQ 93? If you
    want your readers to actually find this reference you must give more
    description.
    Finally, you would do well to find somebody whose native tongue is
    English to polish your language.
  9. Vey
    Vey Guest
    I'm not seeing that.
  10. Pooh Bear
    Pooh Bear Guest
    Probably browser dependent which indicates the page code needs sorting.
    Graham
  11. Vey
    Vey Guest
    That's what I figure. But I'm not willing to break my browser to sort it.
    IE6 and TB1.5 these days that's about all I worry about. The others are
    in the >5% range.
  12. Phil Allison
    Phil Allison Guest
    "Vey"
    ** Then you are not using IE with Windows XP set to larger fonts.
    The overwriting problem is rare and generally only seen on sites created by
    amateurs.
    ........ Phil
  13. Vey
    Vey Guest
    That's exactly right Phil, I'm not. You fit into the >5% classification,
    then.
  14. Vey
    Vey Guest
    But don't feel bad, Phil. You have good company. The Mac users with OS7
    are right in there with you. They also claim that "only amateurism"
    creates pages they can't see properly.
    Yes, pages can be created so that you see them properly. Too bad they
    are designed for IE4 & NS3.
  15. Phil Allison
    Phil Allison Guest
    "Vey"
    ** What a shame you cannot afford a decent PC.
    ** You have the arrow the wrong way - fuckwit
    XP & IE dominate the PC world.
    ......... Phil
  16. Phil Allison
    Phil Allison Guest
    "Vey"
    ** This IS one very slimy piece of asinine wog shit for sure.
    ** "Vey" fits right into the classification of a demented scumbag.
    ** Now the slimy pile of wog shit has resorted fabricating false quotes.
    Here is a real one.
    " The overwriting problem is rare and generally only seen on sites created
    by
    amateurs. "
    ** Now the slimy pile of wog shit fabricates a completely false scenario.
    Sure has a monstrous axe to grind over something.
    Tiny cock syndrome - I bet.
    ......... Phil
  17. Vey
    Vey Guest
    Thanks Phil.
    I needed that.
    I'll be sure to tell anyone here to plonk you.
  18. Phil Allison
    Phil Allison Guest
    "Vey"
    ** This wog asshole very clearly psychotic.
    B E W A R E !!
    ......... Phil
