Amstrad VCR6000 Will Not Accept Tape
Discussion in 'Electronic Repair' started by BobK, Nov 24, 2005.
  1. BobK
    BobK Guest
    I have an Emerson VCR6000 (manufactured in 1996). I believe it is a
    rebadged Amstrad VCR6000.
    The VCR will not accept a cassette. When a tape is push in, the load
    mechanism pulls it in for about .3 seconds and 1/2" before spitting it
    back out. Internally, the load motor eject the mechanism to its limit
    and then spins on the belt for a couple seconds before turning off.
    The VCR then shuts down. If I manually rotate the motor and fully seat
    the tape. The VCR operates normally. There is no indication of a
    jammed load mechanism.
    As I poke around inside, it appears there might be a problem with the
    light sensors. There are two solutions on the EURAS database, but I
    don't have access.
    I'm competent with electonics repairs once I have a solution to follow.
    Any suggestions?
  2. BobK
    BobK Guest
    Additionally, the load motor belt is not slipping. It only slips
    during the fault when the basket is fully ejected to its limit. Then
    for a couple seconds the motor continues to operate, which causes the
    belt to slip.
    Again, once the tape is manually cycled into place, all VCR functions
    work properly. Additionally, the eject button works properly. The
    basket ejects without a single problem. Only while trying to insert a
    cassette does the fault occur.
  3. JR North
    JR North Guest
    I think the load belt IS slipping, only you can't see it. The logic
    looks for the load to complete quickly. If no, the unit will detect a
    basket jam, eject and shut down. It can't tell the difference between a
    jam and a slipping load belt.
    JR
  4. BobK
    BobK Guest
    JR,
    If the belt was slipping a bit, I think I could overcome it by
    aggressively assisting the basket while the tape is loading. However,
    no amount of pushing makes a difference. I'll take a second look at
    the belt.
    Any other ideas in the meantime?
  5. BobK
    BobK Guest
    For archive's sake, I found the problem.
    On the bottom of the cassette mechanism near all the take up reel
    gearing is a black piece of plastic about the size of a 50 cent piece.
    It is held into place by one screw and a couple of little plastic nubs.
    While in place, you can see that there is a grey gear underneath the
    black plastic piece that engagea a white gear of the take up reel.
    Look carefully and make sure you know how the grey gear is aligned.
    There is a small half cutout on the edge of the gear as an indicator.
    I made sure the half cutout on the grey gear was aligned with the dot
    on the white gear.
    Remove the grey gear by popping it out of the black plastic holder. On
    the bottomside of the grey gear are four metal contacts and on the
    inside of the black plastic are metal strips where the contacts,
    well...make contact. Mine were dirty. I used an eraser to clean
    everything up. Also, on the outside of the black plastic piece is a
    connector with contacts that go into the main circuit board. Mine were
    also dirty and I cleaned them up with an eraser. I put everything back
    together and the machine now ejects properly. Apparently, the grey
    gear with the little metal fingers feeds info to the main processor
    when the tape is loading. Dirty contacts caused the problem.
  6. b
    b Guest
    seen this before.
    first check and clean the mode switch - common problem on this model.
    then remove the cassette basket. On the right hand side is a cam (black
    if i recall). there are 2 leaf switches which have probably got bent
    out of their correct position or are dirty - retension and clean.
    Ben
  7. b
    b Guest
    seen this before.
    Ben
  8. b
    b Guest
    seen this before.
    Ben
  9. b
    b Guest
    seen this before.
    Ben
