Amplitude Modulation
Discussion in 'General Electronics Discussion' started by helios1, Jun 6, 2012.
  1. helios1
    helios1
    9
    May 9, 2012
    Which is the best choice for a carrier signal in amplitude modulation? A sine or square? and why?
  2. Harald Kapp
    11,319
    2,595
    A sine, of course.
    If you use any other waveform, you will create sidebands at the harmonics of the carrier frequency.
    1) you will have to filter (remove) these side bands, otherwise you will disturb other signals.
    2) you put energy into these sidebands that is lost for the main purpose, because it gets filtered (see 1).
    Using a sine as carrier gives you the most bang for the buck, so to speak.
    Harald
  3. helios1
    helios1
    9
    May 9, 2012
    Thanks Harald!
