amplifiers
Discussion in 'Electronic Basics' started by upasna, Jun 25, 2008.
  1. upasna
    upasna Guest
    the output of an amplifier is a square wave when the input is a sine
    wave.what is the explanation for this?
  2. One reason could be overloading the input to the amp.
    Rheilly P
  3. Hammy
    Hammy Guest
    The opamp output can only swing to the rails or close to it depending
    on the opamp.If your output signal is larger then your rail voltage
    you get clipping.See here.
    http://www.seas.upenn.edu/~ese205/Labs06/Lab5.html
  4. To give you something to think about for homework??
  5. Phil Allison
    Phil Allison Guest
    "upasna"
    ** More than one possible explanation exists - since the characteristics of
    your " amplifier " have not been defined.
    Define them now.
    ...... Phil
  6. upasna
    upasna Guest
  7. Jamie
    Jamie Guest
    Saturation of the amp?
    Over driving the input?
    incorrect amp type ?
    something wrong with the amp?
    http://webpages.charter.net/jamie_5"
  8. neon
    neon
    1,325
    Oct 21, 2006
    if the frequency output are the same then you overdriving the input. if the freqency is much higher then it just plain oscillates for some reasons
