Amplifiers, Rails and current sources
Discussion in 'Electronic Design' started by john, Jan 12, 2006.
  1. john
    john Guest
    Hello,
    Please look at the following data sheet of an instrumentation amplifier
    INA2133.
    http://focus.ti.com/lit/ds/symlink/ina2133.pdf
    I am using it as a constant current source ( figure 16, page 13 ). I
    made the following changes in the circuit
    1. I put a capcitor in series with the load for AC coupling reason.
    2. The power supply of the circuit is +/- 15 volts.
    I have a following questions about the circuit.
    1. For example, if the circuit is producing 100microA and the load
    resistance is 1mega ohm then the complaince voltage will be +/- 10
    volts or the voltage across the load will be +/- 10 volts. How can I
    keep the complaince voltage or voltage across the load equal to +/-
    0.7 volts with the current of 100microA without changing the power
    supply which is +/-15 volts?
    Please advice!
    John
