R
Ron
Usually it's current gain that's matched. I've never specified matched
pairs in any design ( pro-audio btw ) in my entire life despite being
responsible for some 10s of thousands of amplifiers out there. It seems
like poor design to need matched pairs to me.
I think the original post is misleading you a bit. The 2245 amp
will run just fine with non-matched output transistors, without
'sever distortion problems'. However, to achieve the lowest possible
distortion and stability, matched pairs are advisable. This is true
for *any* symmetrical audio amplifier design.
Some circuits almost don't care. It depends a lot on the driver stage.
True. Especially for low NFB, low gain designs. Still the better
the complimentary paiss match, the better will the amplifier be.
Incidentally I can't really see how a failed output device can be
responsible for severe distortion. Normally it's a works or not
situation with output devices.
Well, when one side of a pair works while the other doesn't, you do
get signal out, but it's seriously (50% and up) distorted. Not just
'poor fidelity' but 'the amp is definitely bad' kind of sound.
I recently had a similar problem with an 2270 output block. I
replaced the bad output device with a matched (measured out of
about a dozen) transistor. The receiver sounds great, but the
repaird channel now measures better than the originally good
one.
-- Ron
