HI 73's de Edd, I've soldered in a DIP16 socket for that IC 4015B and went ahead and ordered a replacement IC for just afew Pence only. So I will give that a try whilst I wait to hear from you regarding IC 604 evaluation for address corruption, given the serial digital stream addresses your display properly responding to inputs. Who knows it may only be that IC defective and it fixes the issue but I doubt it purely because of the fact that the volume is louder when Video 2 is selected. Oh hang on though, thinking about this a little further this behaviour now its not unexpected. We have off course now got IC604 floating on the instruction side to IC601 & 602, but we don't have the attenuation sides of that 4015IC floating also. So when we press the front source select buttons:-
1. The buttons action is sensed by the front PCB controller IC which changes the display.
2. The controller IC should then be sending signals to IC604 to change its binary output config to suit the source selected. because these are floating that has no effect of course you can cycle through them but...
3. Because pins 2, 11,12,13 of IC 604 are not floating, when cycling through them, attenuation changes when Video 2 is selected, i.e louder than the rest.
I'm learning alot here, but no quite there on why the IC604 isn't changing its binary output.
Oh one other observation, I posted on March 4th a query re the components in parallel to the serial connection between the IC's in question here. It has now dawned on me that these are for providing instructions to the optional Digital Audio Tape machine. Because I don't have that I may just remove these components to see if they have interfered with the signals to IC601 & 602
