Amp probe questions
Discussion in 'Electronic Basics' started by Ryan, Nov 14, 2006.
  1. Ryan
    Ryan Guest
    This falls outside the realm of small voltages on small circuits, so
    redirects appreciated.
    If I am using an amp probe to sense the current flow through wires in a
    breaker box and I probe something like 8.33 amps on a 120v circuit (1000
    watts) then I believe I can deduce that this consumes a kilowatt in 1
    hour and costs me approx $0.09 at my residential rate.
    As I understand North American 240v service, each pole runs 180 degrees
    off the other and consumption of current on one side "should" equal the
    other. If I probe 8.33 amps on one wire of a 240v circuit (dual pole
    breaker) then is this also consuming 1 kilowatt per hour, or do I need
    to calculate my reading of 8.33 amps and double it to 16.66?
    I'm trying to audit my energy bills compared to ambient electricity
    consumption and I'm not certain if I am doing the math properly with the
    220v circuits.
    When a 220v breaker is rated for 30 amps, is that 15+15 amps or 30+30 amps?
    Thank you.
    (Very tempted to get an RS-485 adapter, run a 100 foot cable, and start
    datalogging my thermostat and graphing HVAC 1st, 2nd, 3rd stage runtimes
    and energy costs)
  2. 30 A per pole.
    prove it.
    Member of DAV #85.
    Michael A. Terrell
    Central Florida
  3. Rich Grise
    Rich Grise Guest
    This consumes one kilowatt, as it's operating. Watts are power, which
    is the _rate_ of doing work; work is pretty much the same as energy. In
    one hour, a one-kilowatt appliance will have consumed one kilowatt-hour,
    which is a unit of energy usage. A 100-watt bulb only uses 100 watts,
    but in ten hours, that's a kilowatt-hour.
    No. That depends on how well-balanced the loads are on the two sides of
    the mains.
    And THEY ARE NOT OUT OF PHASE!!!!!!!!!!! THEY ARE PERFECTLY IN PHASE BUT
    OPPOSITE POLARITIES! They're the two ends of a center-tapped transformer,
    there's no phase-shifting component there.
    The power company doesn't like you to run unbalanced loads, but I'd
    think that the pole pig (the CT 240V tranny) would compensate for that -
    just half its windings would be transferring power.
    Well, this isn't exactly the way it works. If it's a ganged breaker, it
    will pop if either leg is drawing over 30 amps, but if both legs are
    drawing 30 amps, it's just 30 amps through the whole thing and there's
    no neutral current. It's like 30 in one wire while 30 goes out the other
    wire simultaneously.
    My pleasure. :)
    If you're going into that detail, just duplicate this for each phase, and
    put in some kind of power factor detection.
    Good Luck!
    Rich
  4. Phil Allison
    Phil Allison Guest
    "Ryan"
    ** Nope - you cannot deduce that at all.
    You need an AC power meter or Kilo Watt Hour ( KWH ) meter to measure
    energy consumption.
    Depending on the nature of the load and the particular " amp probe " in use,
    the figure obtained by making that over simple calculation can be double or
    more the actual wattage figure.
    BTW
    Does " amp probe " = an AC current clamp meter or something else ?
    Really helps if you are more forthcoming with important details like this.
    ........ Phil
  5. Do you live in a home, condo or apartment?
  6. Ryan
    Ryan Guest
    The reading is obtained with a Fluke T5-1000.
  7. Ryan
    Ryan Guest
    My residence is a house (home).
  8. Ryan
    Ryan Guest
    I have heard people refer to it as 2-phase and to call 120v service
    single phase. I think your assertion makes sense, however.
    Is this also true with "3-phase" service, such as commercial delta or
    wye configurations? Is it actually 3 polarities or different phases in
    that event?
    This sounds interesting. Is this done between the meter base and the
    panel? I'm curious with what components this is done.
  9. Phil Allison
    Phil Allison Guest
    "Ryan"
    ** Replacing what this smug pig snipped.
    " Nope - you cannot deduce that at all.
    energy consumption. "
    ** Absence of reply noted.
    ** That is an average responding meter - so cannot even give a current VA
    figure let alone true power in watts.
    ......... Phil
  10. A single home usually has 240 VAC split into two 120 VAC 'sides'.
    A condo or apartment will usually have 2 phases of 3 phase 208 VAC -- 120
    VAC line to neutral.
  11. Then you should have 120 + 120 = 240 VAC.
  12. Rich Grise
    Rich Grise Guest
    Yes, 3-phase is actually 3 phases, 120 degrees from each other. They come
    from the generator that way - there are three windings that are actually
    120 degrees from each other around the circle (or some fraction of that,
    depending on the number of poles, but that's a different quesiton.)
    Well, I'm thinking a current transformer on each leg, and a voltage
    sense, and use a micro to do the arithmetic to get true power and power
    factor.
    Cheers!
    Rich
