Amp keeps going into protection mode
Rick79
Nov 26, 2014
283
Nov 26, 2014
283
O.K.
Please mark that point on the "dial".
Now open D10 (cut it like you did for D8).
With both D8 and D10 open,does the amp go into protection?If it does, at what point?
Measure with the DMM in "diode mode test" D8,D10 and invert polarity, what do we get?
O.K.
Rick79
Nov 26, 2014
283
Nov 26, 2014
283
OK I cut D10 so both D10 & D8 are disconnected. Amp goes into protection at the same point like it was when just D8 was cut.
D8 reads .612 ohms & nothing flipped
D10 ohms .616 ohms & nothing flipped
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
O.K ,
Now cut D9 .
With all 3 diodes D8-D10 cut .Does the amp go into protection?If so at what point?
Measure D9 as you did for D8 and D10,what do we get?
Rick79
Nov 26, 2014
283
Nov 26, 2014
283
O.K ,
Now cut D9 .
OK with D8, D9 & D10 disconnected, the amp doesn't go into protection at all, I can turn the volume up real high.
D9 reads .618 and nothing flipped.
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
All diodes measure fine(about 0.6 and flipped Infinity).
Please measure R2 ,R3,and R8 (in circuit) and flip the probes.
What kind of capacitors have you bought?
They should be low ESR and I guess audio grade as well.
Could you please show a photo of the "old and new" ones.
Rick79
Nov 26, 2014
283
Nov 26, 2014
283
Check R2 R3 & R8 in Diode mode? Amp off?
The pair in one photo are the old capacitors. The single ones in the other photos are the new ones.
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
In diode mode and in ohm mode
Rick79
Nov 26, 2014
283
Nov 26, 2014
283
In Diode mode...
R2 nothing & nothing flipped
R3 .085 & nothing flipped
R8 1.439 & nothing flipped
In Ohms Mode...
R2 9.81
R3 97.1
R8 46.3
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
R3 reading of 0.085 is too low, that makes Q2 a suspect.
Can you please confirm that reading?
If it confirms ,then de-solder Q2 ,take it out and measure it in Diode Mode.
Note Q2 connections on the board before you take it out.
Check between B-E and B-C and C-E and flip (a total of 6 measurements).
on the capacitors:
The Capacitors you bought are from Marcon ,a good Japanese company(if genuine).
But,the date code is very old 1992 ...
In fact, that company was bought by another firm somewhere in the mid 90's.
Is there any way you can check capacitance and ESR somehow elsewhere?
Rick79
Nov 26, 2014
283
Nov 26, 2014
283
on the capacitors:
Sorry, that zero was supposed to be a six
R3 reads .685
No, I have no other way of testing capacitors.
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
O.K
We shall re-solder the diode gradually,and test while we do that.
We now have all diodes cut ,correct?
Let's Start with re-soldering D9,going into protection?
If so, at what level?
Rick79
Nov 26, 2014
283
Nov 26, 2014
283
on the capacitors:
O.K
Yes, they are all still cut.
OK, I just soldered D9 back. The amp doesn't go into protection at all
dorke
Jun 20, 2015
2,342
Jun 20, 2015
2,342
Can you please measure the DC voltage (2V range) on R2 at minimum-volume and max-volume volume.
