American/Canadian power connectors
R
Ron Eggler
I've moved to N America from Europe and I'm changing some power connector.
My Question now is, when I look from the front on the connector, Ground on
the bottom, is the phase on the left or on the right? I unfortunately don't
have a phase tester handy.
Ron
JeffM
[...]is the phase on the left or on the right?
http://www.alpharubicon.com/altenergy/images/wiringjaden1640.jpg
Next time you have a question, Google it.
http://www.google.com/images?q=wiring-an-outlet+hot+neutral
I unfortunately don't have a phase tester handy.
This can be determined with any voltmeter--or even a light bulb.
On 117VAC, if you have more than a fraction of a volt
between Neutral and Ground, you have a problem.
