If you are that open minded be careful your brains don't fall out when
you bend over.
Delusional nonsense. Nothing useful and not worth watching beyond the
first few minutes.
Also total nonsense. Cometary brightness models are not perfect but
basically they do work according the expected volatility of their
constituents. We can actually see two clear tails on comets. One of
light ions that pretty much points directly away from the sun and is
blueish, and a second heavier white dust tail that sits along the
trajectory of the comets movement give or take a bit of drift from the
influence of light pressure.
Hale Bopp showed both tails very clearly and was a naked eye object to
boot.
http://en.wikipedia.org/wiki/Comet_Hale-Bopp
It also helped eliminate one cult of delusional nutters (Heavens
Gate). Darwin award and bar.
Modern spectroscopy allowed the tails to be analysed remotely. We have
even flown spacecraft into comets.
This is Velikovskyism in some new age form. Barking mad isn't quite
rude enough to describe it.
And almost as delusional as Nancy and the Zetas or Ed Conmans "Man as
Old as Coal" claims.
Could it solve the 'dark matter' question ?
Only by replacing it with total bullshit.
Regards,
Martin Brown
