Amateur (hack) needs a little guidance...
C
C Logan
I am simply a hack at electronics but I need a little help...
I have two cats. One is fat because it eats the other one's food. I have
create a special sensor using simple reed sensor switches, a 9 volt and a
piezo buzzer. There is a magnet attached to the cats collar. It works
quite well, when the cat approaches, the magnet triggers one of the reed
switches to close setting off the buzzer.
The problem is that the buzzer only buzzes for a micro - second as the
magnet passes over the reed switch. I want a simple circuit or relay that
stays on for say 5 seconds. When the reed switch closes, it sends 9 volts
to the piezo...isn't there a simple relay or simple basic circuit that can
hold a relay or switch closed for 5 seconds and then open again?
P
P.M. Groen
Try a Schmitt-trigger circuit. Google for it.
John Larkin
Just hang an electrolytic capacitor across the piezo. The sound will
fade out over a period of time; the bigger the cap, the more time.
Piezo oscillators don't use much current.
That's the simplest way to do it.
John
B
Bob Masta
The name of the type of circuit you are looking for is a "monostable",
more commonly known as a "one shot". A pulse of any duration
sends the output high, and then it stays high for a time determined
by a resistor-capacitor time constant. You can buy ICs that are
dedicated monostables, but I usually prefer to wire up something
simpler from a CMOS gate. Don Lancaster's "CMOS Cookbook"
has a number of circuits, but you can probably find plenty on the
Web via Google.
Bob Masta
dqatechATdaqartaDOTcom
D A Q A R T A
Data AcQuisition And Real-Time Analysis
www.daqarta.com
I
Ian Stirling
And leads to the reed switch welding after a few dozen applications.
C
C Logan
Dear Bob or others who might help:
First of all, the information provided by Bob was excellent, and I was
able to find an excellent circuit, which I promptly built, and it
works excellent. The circuit I built on the 555 is here.
http://www.kpsec.freeuk.com/breadb.htm
Anyhow, I replaced the switch with magnetic reed switches, and placed
a piezo buzzer in the LED slot. Works excellent except for one thing.
The output voltage is too low...power is supplied by a 9 volt
battery, but it is too quiet because the circuit apparently reduces
output voltage significantly. Any suggestions out there?
-CL
R
Robert C Monsen
[email protected] (Bob Masta) wrote in message
First, on s.e.b, please reply at the bottom of a post, never at the
top. This is simply a convention.
Secondly, you can use a pass transistor to get around the
current/voltage limiting using an external transistor, like this:
9V
|Buzzer|
1k |
Output ___ |/
From -|___|- -| NPN like 2N2222 from Radio Shack or Maplin
555 |>
GND
created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
When the output of the 555 goes high, it'll turn on the NPN
transistor, allowing current to flow.
M
Michael A. Covington
Is your 555 a CMOS version (LMC555, TLC555) or a bipolar version (NE555)?
Try the latter; it can conduct quite a bit more current.
