john jardine
Just read this post while currently receiving grief from a scope versus
spectrum analyser contest.
I'm checking the levels and frequencies coming out of a balanced mixer
design being fed by 2 audio frequencies. All was well until I made a mod to
the wiring on the protoboard. Bugger!, lost the mixing products and was
just left with 2 audio frequencies. Mixer output still looked fine on
scope so spent next 15 minutes chasing up the problem. A few mins ago found
I'd miswired the audio and was looking at a 'real' mixing of 2 signals,
hence no multiplier products on the SA.
What's troubling me is that the scope was leading me along me by showing a
neat and clean DSBSC signal. Tweeked the frequencies a little and the scope
moved to a 'normal' mixed audio-on-audio signal.
Can't leave well alone, so wired the (asynchronous) 50ohm audio sources to
10K resistors with their junction to the scope and started looking for audio
mixtures that 'look' like DSBSC. To this end I dropped the frequencies down
to see the scope spot tracking across the screen (0.5 sec per div =no visual
artefacts) and am now looking at a nice DSBSC signal that I know isn't a
DSBSC signal. It's 4Hz 2Vpp and 4.4Hz 2Vpp. It all adds up in the wash but
aint half a confusing time waster!.
john
You can look at it as "multiplication" or "mixing"-- both are at least
partially correct.
But if you look at the output waveform on a scope, you have this
waveform where the RF amplitude gores UP and DOWN, all the way down to
ZERO, so in some sense the carrier sure LOOKS like it's going down to
zero. And if you think of the B+ voltage going to zero, it's hard to
imagine how the carrier can still be going out when the plate voltage
is zero.
So it's at least partially incorrect to say the carrier "stays the
same" and "sidebands pop up".
john
