On Feb 6, 5:46 pm,
[email protected] wrote:
If you make the AM radio a phase lock loop, you can get some
improvement in the interference rejection.
What makes you think that?
The PLL locks onto the carrier and has a filter with a low bandwidth.
This means that the phase of the VCO won't change due to noise that is
far from the carrier. For purposes of understanding why it works,
assume that the VCO is running exactly in step with the carrierand
that in effect the PLL has zero band width.
Now consider the side bands that get demodulated. A noise component
that can be thought of as resulting in a signal like:
Y = f(t) * cos(wt) + sin(wt)
where:
Y = the signal
f(t) = some random (noise) function with no DC
sin(wt) = the carrier
cos(wt) = 90 degrees to the carrier
is the important one for the argument. This signal will result in
noise from a standard AM demodulation but no noise from the PLLand
sync demodulation one.
Now consider the intelligence on the AM signal. It is a function
like:
Y = f(t) * sin(wt) + sin(wt)
The two methods of doing the AM demodulation give equal values for
this input.
The result is that the PLL based method makes the same signal and less
noise on its output.
Maybe in theory you are right. But anyone with a radio that has
synchronous demod will testify that synch demod doesn't help witha
noise source.
3dB of improvement may be hard for people to notice but it is none the
less real.
It is good for rejecting noise from the adjacent channel
if you passband shift.
It prevents the carrier on the adjacent channel from multiplying with
anything so it keeps all of its side bands at high frequencies so yes
it does a good job of that.
The magnetic loop really does the job. The designs that float theloop
above ground are more effective. [The Wellbrook does that.]
huh?
Some loops are built over a ground plane, other use a transformer and
float above the ground.
I'm pretty sure I'd hear a 3db reduction in noise with synchro.
