AM modulator with MC1496 project problem
tzitzikas
May 9, 2010
16
May 9, 2010
16
Hello, i have done this project. It is an experimental oscillator - modulator for mw frequencies. The schematics are here:
oscillator:
http://tzitzikas.webs.com/oscillator-1.JPG
modulator:
http://tzitzikas.webs.com/modulator-1.jpg
The problem is that the designer told me to use an 1kohm variable series resistance between oscillator and modulator (after
c9=22n capacitor of oscillator) to adjust the carrier level. I saw that the 1kohm variable series resistance is not enought
because with 1kohm series resistance the audio was't very good. I think that the carrier level was high. So i change this
resistance with another 4.7kohm. Now i am using about 2kohm of this series resistance. The modulation is very good But i
think that the audio signal in the radio is not at the center of the frequency but a little above.
(The operation frequency is 1000khz but i listen the audio with quality and strong voice at 1003khz.)
which is the problem? how i can fix it, to listen the audio very well at center frequency and not at sideband?
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Have you confirmed that your carrier is actually 1MHz? On the other hand, are you sure your receiver is accurate?
Those would be the first things I'd look at.
edit: You're using a VCO. It's amazing you're within 0.3% of the frequency you're after without some form of feedback (PLL?). I would be less than surprised if the frequency doesn't wander around with temperature, humidity, and possibly even phase of the moon.
55pilot
Feb 23, 2010
434
Feb 23, 2010
434
Considering the problems I pointed out with the other circuit you posted from this source, I suspect the problem is a poor design. I would look at things like not taking component tolerances and other real life issues into account.
To answer your question any further, I would need to read up on the chips in question since I am not familiar with them. Like I suggested in your other thread, I would go back to the website you got the circuit from and ask a few questions there.
---55p
tzitzikas
May 9, 2010
16
May 9, 2010
16
55pilot :the circuit is from a Greek website.
(*steve*): i controll the vco , by using a pll with SAA1057 and pic16f628 microcontroller.
Do you have any idea why the modulation is not at the center frequency? Maybe improper armour?
(*steve*)
25,510
25,510
Armour? Shielding? I doubt it. That's more likely to introduce noise than a systematic frequency error.
Have you independently measured the carrier frequency?
tzitzikas
May 9, 2010
16
May 9, 2010
16
yes i have measured the carrier frequency. It is ok. i work the vco with pll (SAA1057 and pic16f628 microcontroller)
i was meaning good sield, sorry.
davenn
14,254
14,254
yes because you appear to have the MC1496 wired as a DSB (double sideband) suppressed carrier modulator. So therefore you are not going to see a signal on the main carrier freq as that freq is suppressed. Rather you are going to see a signal on the 2 sideband freqs.
VK2TDN
tzitzikas
May 9, 2010
16
May 9, 2010
16
VK2TDN
do you know what modifications i must do at this circuit http://tzitzikas.webs.com/modulator-1.jpg to work as am modulator? the designer claims that this schematic is for am modulation.
